Salta al contenuto principale
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
Cosa ti serve
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: passo 1, immagine 1 di 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 2, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 2, immagine 2 di 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 3, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 3, immagine 2 di 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, immagine 1 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, immagine 2 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 4, immagine 3 di 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, immagine 1 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, immagine 2 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 5, immagine 3 di 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 6, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 6, immagine 2 di 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 7, immagine 1 di 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 8, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 8, immagine 2 di 2
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: passo 9, immagine 1 di 1
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 10, immagine 1 di 1
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, immagine 1 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, immagine 2 di 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 11, immagine 3 di 3
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: passo 12, immagine 1 di 1
    • Remove the power switch from the front panel once the white plastic frame is removed.
Conclusione
Tamara Titus
Membro da: 09/03/15
157 Reputazione
1 Guida realizzata
USF Tampa, Team 15-2, Blackwell Fall 2015 Membro di USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,086
