Salta al contenuto principale
Philips Norelco BeardTrimmer 3100 Handle Replacement
Cosa ti serve
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: passo 1, immagine 1 di 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 2, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 2, immagine 2 di 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 3, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 3, immagine 2 di 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 4, immagine 1 di 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 4, immagine 2 di 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 4, immagine 3 di 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 5, immagine 1 di 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 5, immagine 2 di 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 5, immagine 3 di 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 6, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 6, immagine 2 di 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 7, immagine 1 di 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 8, immagine 1 di 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: passo 8, immagine 2 di 2
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 15-2, Blackwell Fall 2015 Membro di USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,736
