Salta al contenuto principale
Philips Norelco 5801XL Front and Back Housing Replacement
Cosa ti serve
  1. Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: passo 1, immagine 1 di 2 Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: passo 1, immagine 2 di 2
    • Remove the two T8 2 mm Phillips screws on the back housing.
  2. Philips Norelco 5801XL Front and Back Housing Replacement: passo 2, immagine 1 di 2 Philips Norelco 5801XL Front and Back Housing Replacement: passo 2, immagine 2 di 2
    • Separate the back housing and the front housing using the plastic opening tool.
  3. Philips Norelco 5801XL Front and Back Housing Replacement: passo 3, immagine 1 di 3 Philips Norelco 5801XL Front and Back Housing Replacement: passo 3, immagine 2 di 3 Philips Norelco 5801XL Front and Back Housing Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tool, carefully pry the inside of the middle bracket towards the outside of the housing in order to remove it.
  4. Philips Norelco 5801XL Front and Back Housing Replacement: passo 4, immagine 1 di 1
    • Remove the two T8 2 mm screws near the bottom of the device.
    • Remove the bracket the screws were holding in place.
  5. Philips Norelco 5801XL Front and Back Housing Replacement: passo 5, immagine 1 di 1
    • Insert the plastic opening tool into the charging port and push inwards.
  6. Philips Norelco 5801XL Front and Back Housing Replacement: passo 6, immagine 1 di 1
    • Remove the two T8 2 mm screws near the top of the device shown here.
  7. Philips Norelco 5801XL Front and Back Housing Replacement: passo 7, immagine 1 di 3 Philips Norelco 5801XL Front and Back Housing Replacement: passo 7, immagine 2 di 3 Philips Norelco 5801XL Front and Back Housing Replacement: passo 7, immagine 3 di 3
    • Cautiously lift and twist the circuit board, then begin sliding the inside assembly forward.
    • After sliding it forward, the whole assembly will separate from the rear housing.
  8. Philips Norelco 5801XL Front and Back Housing Replacement: passo 8, immagine 1 di 1
    • The housing and the inside assembly should be completely separated.
Conclusione
Now, you can put the new housing on. To reassemble your device, follow these instructions in reverse order.
Ben Gibbs
Membro da: 02/16/16
361 Reputazione
3 Guide realizzate
IUPUI, Team 3-2, Harley Spring 2016 Membro di IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 632
