Salta al contenuto principale
Philips HD9252 Transformer Replacement
Cosa ti serve
  1. Philips HD9252 Transformer Replacement, Top: passo 1, immagine 1 di 1
    • Insert a nylon spudger underneath the top of the device.
    • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
  2. Philips HD9252 Transformer Replacement: passo 2, immagine 1 di 1
    • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
  3. Philips HD9252 Transformer Replacement: passo 3, immagine 1 di 1
    • Remove the top by lifting it upwards and setting it down.
  4. Philips HD9252 Transformer Replacement, Transformer: passo 4, immagine 1 di 1
    • Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
  5. Philips HD9252 Transformer Replacement: passo 5, immagine 1 di 1
    • Remove the top piece, using a Phillips #2 screwdriver, to get the whole transformer.
  6. Philips HD9252 Transformer Replacement: passo 6, immagine 1 di 2 Philips HD9252 Transformer Replacement: passo 6, immagine 2 di 2
    • Remove the brown and white wire attached to the transformer using a spudger.
    • Disconnect both the brown and white cables.
  7. Philips HD9252 Transformer Replacement: passo 7, immagine 1 di 1
    • Replace the transformer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 96
