Salta al contenuto principale
Philips DVP5992-F7 Tray Replacement
Cosa ti serve
  1. Philips DVP5992-F7 Tray Replacement, Tray: passo 1, immagine 1 di 3 Philips DVP5992-F7 Tray Replacement, Tray: passo 1, immagine 2 di 3 Philips DVP5992-F7 Tray Replacement, Tray: passo 1, immagine 3 di 3
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: passo 2, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 2, immagine 2 di 2
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: passo 3, immagine 1 di 3 Philips DVP5992-F7 Tray Replacement: passo 3, immagine 2 di 3 Philips DVP5992-F7 Tray Replacement: passo 3, immagine 3 di 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: passo 4, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 4, immagine 2 di 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: passo 5, immagine 1 di 3 Philips DVP5992-F7 Tray Replacement: passo 5, immagine 2 di 3 Philips DVP5992-F7 Tray Replacement: passo 5, immagine 3 di 3
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: passo 6, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 6, immagine 2 di 2
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: passo 7, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 7, immagine 2 di 2
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: passo 8, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 8, immagine 2 di 2
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: passo 9, immagine 1 di 2 Philips DVP5992-F7 Tray Replacement: passo 9, immagine 2 di 2
    • Lift the tray out of the DVD player from the back.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 516
