Salta al contenuto principale
Philips DVP5992-F7 HDMI port Replacement
Cosa ti serve
  1. Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, immagine 1 di 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, immagine 2 di 3 Philips DVP5992-F7 HDMI port Replacement, HDMI port: passo 1, immagine 3 di 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 HDMI port Replacement: passo 2, immagine 1 di 2 Philips DVP5992-F7 HDMI port Replacement: passo 2, immagine 2 di 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 HDMI port Replacement: passo 3, immagine 1 di 3 Philips DVP5992-F7 HDMI port Replacement: passo 3, immagine 2 di 3 Philips DVP5992-F7 HDMI port Replacement: passo 3, immagine 3 di 3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 HDMI port Replacement: passo 4, immagine 1 di 1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 HDMI port Replacement: passo 5, immagine 1 di 1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 HDMI port Replacement: passo 6, immagine 1 di 1
    • Remove the motherboard from the DVD player.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 281
