Salta al contenuto principale
Philips DC320 37 Speaker Replacement
Cosa ti serve
  1. Philips DC320 37 Speaker Replacement, Removing Philips DC320 37 Bottom Panel: passo 1, immagine 1 di 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Speaker Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Speaker Replacement: passo 3, immagine 1 di 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Speaker Replacement: passo 4, immagine 1 di 3 Philips DC320 37 Speaker Replacement: passo 4, immagine 2 di 3 Philips DC320 37 Speaker Replacement: passo 4, immagine 3 di 3
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  6. Philips DC320 37 Speaker Replacement: passo 6, immagine 1 di 3 Philips DC320 37 Speaker Replacement: passo 6, immagine 2 di 3 Philips DC320 37 Speaker Replacement: passo 6, immagine 3 di 3
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  7. Philips DC320 37 Speaker Replacement: passo 7, immagine 1 di 1
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  8. Philips DC320 37 Speaker Replacement: passo 8, immagine 1 di 2 Philips DC320 37 Speaker Replacement: passo 8, immagine 2 di 2
    • Slide the speaker towards the bottom of the device to remove.
Conclusione
Graham Rolph
Membro da: 04/18/13
1 Reputazione
2 Guide realizzate
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 888
