Salta al contenuto principale
Philips DC320 37 Headphone or Power Jack Replacement
Cosa ti serve
  1. Philips DC320 37 Headphone or Power Jack Replacement, Removing Philips DC320 37 Bottom Panel: passo 1, immagine 1 di 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: passo 3, immagine 1 di 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: passo 4, immagine 1 di 3 Philips DC320 37 Headphone or Power Jack Replacement: passo 4, immagine 2 di 3 Philips DC320 37 Headphone or Power Jack Replacement: passo 4, immagine 3 di 3
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: passo 5, immagine 1 di 1
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: passo 6, immagine 1 di 1
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: passo 7, immagine 1 di 1
    • Separate the white suport bracket from the headphone/power electronics board.
Conclusione
Graham Rolph
Membro da: 04/18/13
1 Reputazione
2 Guide realizzate
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,238
