Salta al contenuto principale
Petzl E03 050 Headlamp Lens Piece Replacement
Cosa ti serve
  1. Petzl E03 050 Headlamp Lens Piece Replacement, Extend the Damaged Lens Piece: passo 1, immagine 1 di 1
    • Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
  2. Petzl E03 050 Headlamp Lens Piece Replacement, Remove the Lens Piece: passo 2, immagine 1 di 1
    • Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
  3. Petzl E03 050 Headlamp Lens Piece Replacement, Attach the New Lens Piece: passo 3, immagine 1 di 1
    • Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
  4. Petzl E03 050 Headlamp Lens Piece Replacement, Secure the New Lens Piece: passo 4, immagine 1 di 1
    • Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
Linea Traguardo
Mike
Membro da: 10/23/14
331 Reputazione
3 Guide realizzate
Baylor, Team 8-10, Williams Fall 2014 Membro di Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 692
