Salta al contenuto principale
Petra KM 31 17 Capacitor Replacement
Cosa ti serve
  1. Petra KM 31 17 Capacitor Replacement, Replace Capacitors: passo 1, immagine 1 di 1
    • Remove the plastic water tank
    • Remove the iron sheet and the underlaying black spillover pan
  2. Petra KM 31 17 Capacitor Replacement, Open: passo 2, immagine 1 di 2 Petra KM 31 17 Capacitor Replacement, Open: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Turn the machine upsidedown and lose the T10 screw right next to the power cord
    • Lose the four clips on the side. Use a spudger or a flathead screwdriver to gently bend the little plastic clip on the outer side of the rectangular hole inwards. Use your other hand and a spudger or a plastic card to lever off the coverage. Do this with all four holes.
  3. Petra KM 31 17 Capacitor Replacement, Remove cords: passo 3, immagine 1 di 3 Petra KM 31 17 Capacitor Replacement, Remove cords: passo 3, immagine 2 di 3 Petra KM 31 17 Capacitor Replacement, Remove cords: passo 3, immagine 3 di 3
    • Disconnect all cords from the circuit board besides the two black ones on the right(marked black on the first picture); these are soldered and therefore cannot be disconnected so easily.
  4. Petra KM 31 17 Capacitor Replacement, Desoldering: passo 4, immagine 1 di 3 Petra KM 31 17 Capacitor Replacement, Desoldering: passo 4, immagine 2 di 3 Petra KM 31 17 Capacitor Replacement, Desoldering: passo 4, immagine 3 di 3
    • Desolder the big yellow 0.68 microf capacitor
    • Solder in the replacement capacitor
    • Sometimes the two smaller capacitors (0.047 microf) are also damaged. Test the machine after step four, if it doesn't properly work, replace these two as well.
Conclusione
Altre 5 persone hanno completato questa guida.
benston
Membro da: 06/08/15
220 Reputazione
1 Guida realizzata
7 Commenti
Die zwei kleineren Kondensatoren haben 0,047µF, nicht 0,47µF.
Ansonsten - Gute Anleitung, hab wieder eine funktionierende Kaffeemaschine.
Danke dafür!
Rainer Kraus - Replica
Du hast Recht, danke für den Hinweis
benston -
Smashing, Thank you. My 4yr old Petra was leaking from thé bottom and by removing thé bottom i saw thé filtre was blocked and was able to clear thé crud.
john collins - Replica
Hallo, ich habe sowas noch nie gemacht (Hausfrau im fortgeschrittenen Alter :-) möchte aber meine Petra retten. Lötkolben ist bestellt, die Maschine ist geöffnet aber jetzt scheitere ich daran, dass ich nicht weiß, wie ich die Kabel abmachen soll! Gibt es da eine Trick? Die sitzen ziemlich fest und ich möchte nichts kaputt machen.
Annette
Annette - Replica
Wooohoooo!!!
Das alte Mädchen läuft wieder - mit einem Ersatzteil für 93 Cent!
Ich (58 Jahre und noch nie vorher gelötet) habe es nach Deiner Anleitung geschafft.
Dankeschön!
Annette - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 53
Tutti i Tempi: 4,495
