Salta al contenuto principale
Petnet SmartFeeder SF10E Battery Replacement
Cosa ti serve
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: passo 1, immagine 1 di 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: passo 1, immagine 2 di 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: passo 2, immagine 1 di 2 Petnet SmartFeeder SF10E Battery Replacement: passo 2, immagine 2 di 2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: passo 3, immagine 1 di 2 Petnet SmartFeeder SF10E Battery Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: passo 4, immagine 1 di 2 Petnet SmartFeeder SF10E Battery Replacement: passo 4, immagine 2 di 2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: passo 5, immagine 1 di 2 Petnet SmartFeeder SF10E Battery Replacement: passo 5, immagine 2 di 2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusione
Cal Poly, Team S13-G7, White Fall 2018 Membro di Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 587
