Salta al contenuto principale
Petmate 29027 Fountain Lid and Pump Replacement
Cosa ti serve
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, immagine 1 di 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, immagine 2 di 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: passo 1, immagine 3 di 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: passo 2, immagine 1 di 3 Petmate 29027 Fountain Lid and Pump Replacement: passo 2, immagine 2 di 3 Petmate 29027 Fountain Lid and Pump Replacement: passo 2, immagine 3 di 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: passo 3, immagine 1 di 2 Petmate 29027 Fountain Lid and Pump Replacement: passo 3, immagine 2 di 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: passo 4, immagine 1 di 3 Petmate 29027 Fountain Lid and Pump Replacement: passo 4, immagine 2 di 3 Petmate 29027 Fountain Lid and Pump Replacement: passo 4, immagine 3 di 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: passo 5, immagine 1 di 2 Petmate 29027 Fountain Lid and Pump Replacement: passo 5, immagine 2 di 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: passo 6, immagine 1 di 2 Petmate 29027 Fountain Lid and Pump Replacement: passo 6, immagine 2 di 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Linea Traguardo
Shidie Ren
Membro da: 05/11/20
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 628
