Salta al contenuto principale
Petlibro Granary WIFI Feeder Technique
Cosa ti serve
  1. Petlibro Granary WIFI Feeder Technique, Take it apart: passo 1, immagine 1 di 1
    • Take machine apart and remove all visible screws. You need a skinny, long screwdriver for this.
  2. Petlibro Granary WIFI Feeder Technique, Identify important wires: passo 2, immagine 1 di 1
    • The infrared sensor has an emitting diode and a receiver. note the receiver on the right side. These are the wires we will clip and attach to each other.
  3. Petlibro Granary WIFI Feeder Technique, Clip and splice: passo 3, immagine 1 di 1
    • Clip both wires leading to the receiver (green/red) and splice these together. This will bypass the infrared sensor.
  4. Petlibro Granary WIFI Feeder Technique, Validate bypass: passo 4, immagine 1 di 1
    • Validate that warning light is gone and device is functional before screwing everything together. We are done.
Conclusione
Altre 3 persone hanno completato questa guida.
Matt
Membro da: 01/06/24
193 Reputazione
1 Guida realizzata
2 Commenti
Very helpful fix(the notation about screws’ location was key); worked perfectly. Expensive feeder is no longer a brick!
Talby - Replica
solved my problem, thank you!
Thuan Pham - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 157
Tutti i Tempi: 2,536
