Salta al contenuto principale
Perfect Cooker RC301M Disassembly
Cosa ti serve
Documento in evidenza
  1. Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: passo 1, immagine 1 di 2 Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: passo 1, immagine 2 di 2
    • Remove the power cord and find a clean flat surface to work at.
  2. Perfect Cooker RC301M Disassembly: passo 2, immagine 1 di 3 Perfect Cooker RC301M Disassembly: passo 2, immagine 2 di 3 Perfect Cooker RC301M Disassembly: passo 2, immagine 3 di 3
    • Remove the lid by unhinging the side tabs.
    • Remove the inner pot and any other contents.
  3. Perfect Cooker RC301M Disassembly: passo 3, immagine 1 di 3 Perfect Cooker RC301M Disassembly: passo 3, immagine 2 di 3 Perfect Cooker RC301M Disassembly: passo 3, immagine 3 di 3
    • Flip the device over and look for the two screws recessed underneath the device.
  4. Perfect Cooker RC301M Disassembly: passo 4, immagine 1 di 3 Perfect Cooker RC301M Disassembly: passo 4, immagine 2 di 3 Perfect Cooker RC301M Disassembly: passo 4, immagine 3 di 3
    • Using a Phillips #2 screwdriver, remove the two 32.8 mm screws.
  5. Perfect Cooker RC301M Disassembly: passo 5, immagine 1 di 1
    • Carefully lift up the bottom to reveal the wires and mechanism.
    • Make sure not to pull it up too much as it is still connected to the device body with the center metal mechanism.
  6. Perfect Cooker RC301M Disassembly: passo 6, immagine 1 di 1
    • The center mechanism is directly in the center of the device and connects the switch to the middle
    • This part of the device raises and lowers the burner to change from the cook to warm function.
    • The two parts of the mechanism are connected by a simple metal “T-shaped” tab.
  7. Perfect Cooker RC301M Disassembly: passo 7, immagine 1 di 3 Perfect Cooker RC301M Disassembly: passo 7, immagine 2 di 3 Perfect Cooker RC301M Disassembly: passo 7, immagine 3 di 3
    • Disconnect the two metal arms.
    • It can be seen that the metal tab must be bent into a “U-shape” in order to fit through the other arm of the mechanism.
    • Take the small chain nose pliers and bend each side of the “T-shaped” tab inwards.
    • Use trial and error to bend the tabs until they are able to fit through the “U-shape” cut out in the other arm.
  8. Perfect Cooker RC301M Disassembly: passo 8, immagine 1 di 2 Perfect Cooker RC301M Disassembly: passo 8, immagine 2 di 2
    • Separate the two parts of the devices.
    • The "U-shape" cut out can now be clearly seen.
    • The T-tab remains in the "U-shape" after slipping through the slot.
Conclusione
Documenti Allegati
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 322
