Salta al contenuto principale
Pentax Super Program Shutter Charging Mechanism Disassembly
Cosa ti serve
    1. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom cover: passo 1, immagine 1 di 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release lever: passo 2, immagine 1 di 1
      • Remove one screw.
      • Lift the release lever and bias spring from the post. Be careful as the spring positioning it is still under tension.
      • Installation Notes: Pay attention to the location of the bias spring during reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove contact pin housing: passo 3, immagine 1 di 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove contact pin housing: passo 3, immagine 2 di 2
      • Work the plastic housing off of the left contact pin. The right contact pin will come off with the housing.
      • If desired, the contact and wire can be fully removed from the camera. Soften the contact adhesive with isopropyl alcohol then gently peel away.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove motor drive coupling: passo 4, immagine 1 di 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove motor drive coupling: passo 4, immagine 2 di 2
      • Remove plastic cover.
      • Remove one screw.
      • The screw is usually quite difficult to remove as it is secured with threadlocker. Use heat (e.g. soldering iron) or a penetrating solvent to soften the threadlocker. Be careful not to strip it.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging linkage: passo 5, immagine 1 di 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging linkage: passo 5, immagine 2 di 2
      • Remove one shoulder screw.
      • Remove two screws.
      • Tilt the left side of the linkage up, then lift it away from the chassis.
      • Installation Notes: Make sure that the tab on the advance lock lever sits forward (in camera) of this lever. When the mirror is charged, the lever should move rearward (in camera) allowing the advance lock to engage.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove wind completion switch: passo 6, immagine 1 di 1
      • Remove one screw.
      • Lift out wind completion switch. Be careful not to deform the contact legs
      • Installation Notes: The contact should be open when the advance lock is engaged (after winding) and closed when the advance lock is disengaged (before winding).
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: passo 7, immagine 1 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: passo 7, immagine 2 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove rewind switch lever: passo 7, immagine 3 di 3
      • Remove one circlip.
      • Lift the lever off the post.
      • Remove the bias spring.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: passo 8, immagine 1 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: passo 8, immagine 2 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove advance lever lock: passo 8, immagine 3 di 3
      • Unhook coil spring from ratchet pawl.
      • Lift off ratchet pawl and shim washer.
      • Remove brass bushing.
      • Lift off advance lever lock.
      • Remove bias spring.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove ratchet plate: passo 9, immagine 1 di 1
      • Remove ratchet plate.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release switch: passo 10, immagine 1 di 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove bottom release switch: passo 10, immagine 2 di 2
      • Remove one screw.
      • Lift out switch assembly.
      • Remove isolator sheet.
      Chiedi a FixBot
      Aggiungi Commento
    10. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: passo 11, immagine 1 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: passo 11, immagine 2 di 3 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove winding spring: passo 11, immagine 3 di 3
      • Keep a finger on top of the winding spring to hold it in place.
      • Unhook the end of the winding spring from the retaining post.
      • Unwind the spring in a controlled manner to prevent shock and breaking.
      • Remove one shim washer.
      • Installation Notes: When coiled and hooked, the spring should not be in contact with any other parts of the camera body. 7-8 wraps is typical.
      Chiedi a FixBot
      Aggiungi Commento
    11. Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging mechanism plate: passo 12, immagine 1 di 2 Pentax Super Program Shutter Charging Mechanism Disassembly, Remove charging mechanism plate: passo 12, immagine 2 di 2
      • Remove one screw.
      • Remove one screw.
      • Remove one slotted retaining post.
      • Remove charging mechanism plate.
      • Remove one plastic washer.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.604 Reputazione
78 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 16
Ultimi 30 giorni: 48
Tutti i Tempi: 246
