Salta al contenuto principale
Pentax Super Program Aperture Coupling Ring Disassembly
Cosa ti serve
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: passo 1, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: passo 1, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove film advance lever: passo 1, immagine 3 di 3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mode dial: passo 2, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mode dial: passo 2, immagine 2 di 2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: passo 3, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: passo 3, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove exposure compensation dial: passo 3, immagine 3 di 3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: passo 4, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: passo 4, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover screws: passo 4, immagine 3 di 3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: passo 5, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: passo 5, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove top cover: passo 5, immagine 3 di 3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove bottom cover: passo 6, immagine 1 di 1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: passo 7, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: passo 7, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove front leatherette panels: passo 7, immagine 3 di 3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB with adjustment pots: passo 8, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB with adjustment pots: passo 8, immagine 2 di 2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder motor drive connections: passo 9, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder motor drive connections: passo 9, immagine 2 di 2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove tripod mount: passo 10, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove tripod mount: passo 10, immagine 2 di 2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Detach ISO resistor assembly: passo 11, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach ISO resistor assembly: passo 11, immagine 2 di 2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: passo 12, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: passo 12, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Detach mode dial unit: passo 12, immagine 3 di 3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder flash sync wires: passo 13, immagine 1 di 1
      • Unsolder two gray wires.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder shutter wires: passo 14, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder shutter wires: passo 14, immagine 2 di 2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: passo 15, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: passo 15, immagine 2 di 2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      Chiedi a FixBot
      Aggiungi Commento
    10. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew front board: passo 16, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew front board: passo 16, immagine 2 di 2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    11. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror box and front board: passo 17, immagine 1 di 1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      Chiedi a FixBot
      Aggiungi Commento
    12. Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Front Block: passo 18, immagine 1 di 1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder Main PCB: passo 19, immagine 1 di 1
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder lens mount connections (early production): passo 20, immagine 1 di 1
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder aperture resistor: passo 21, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder aperture resistor: passo 21, immagine 2 di 2
      • Unsolder two yellow wires for the aperture resistor.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: passo 22, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: passo 22, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder eye piece: passo 22, immagine 3 di 3
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder front board connections (early production): passo 23, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Unsolder front board connections (early production): passo 23, immagine 2 di 2
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB connection (late production): passo 24, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach flex PCB connection (late production): passo 24, immagine 2 di 2
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax Super Program Aperture Coupling Ring Disassembly, Detach viewfinder LCD: passo 25, immagine 1 di 1
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: passo 26, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: passo 26, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror governor: passo 26, immagine 3 di 3
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax Super Program Aperture Coupling Ring Disassembly, Remove main PCB: passo 27, immagine 1 di 1
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Detach front flex PCB: passo 28, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Detach front flex PCB: passo 28, immagine 2 di 2
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove beeper: passo 29, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove beeper: passo 29, immagine 2 di 2
      • Remove one screw and retainer plate.
      • Remove beeper.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: passo 30, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: passo 30, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Unscrew mirror box: passo 30, immagine 3 di 3
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove mirror box: passo 31, immagine 1 di 1
      • Lift mirror box away from front lens board.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Mirror Box: passo 32, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Installation Notes: Mirror Box: passo 32, immagine 2 di 2
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: passo 33, immagine 1 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: passo 33, immagine 2 di 3 Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture resistor: passo 33, immagine 3 di 3
      • Unsolder two yellow wires.
      • Remove two screws.
      • Clean resistive strip with isopropyl alcohol.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax Super Program Aperture Coupling Ring Disassembly, Remove depth of field preview lever: passo 34, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove depth of field preview lever: passo 34, immagine 2 di 2
      • Remove one pin head screw.
      • Remove coupling lever.
      • Remove bias spring.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax Super Program Aperture Coupling Ring Disassembly, Remove ring retainer plates: passo 35, immagine 1 di 2 Pentax Super Program Aperture Coupling Ring Disassembly, Remove ring retainer plates: passo 35, immagine 2 di 2
      • Remove two screws and retainer plate.
      • Remove loose spring.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax Super Program Aperture Coupling Ring Disassembly, Remove aperture coupling ring: passo 36, immagine 1 di 1
      • Gently lift out aperture coupling ring. It is still attached.
      • Unhook coil spring.
      Chiedi a FixBot
      Aggiungi Commento
      • Clean the aperture coupling ring and the track it sits in with isopropyl alcohol.
      • When assembled, the ring should rotate smoothly and quickly snap back to its home position.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.604 Reputazione
78 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 37
Tutti i Tempi: 185
