Introduzione
Button replacement may be necessary if the shutter button sticks or no longer activates shutter due to wear.
Cosa ti serve
Using the J0 screwdriver, remove the 6.3 mm screw.
Remove the 6.3 mm screw using a J0 screwdriver.
With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
