Salta al contenuto principale
Pentax Optio S4i Front and Back Cover Replacement
Cosa ti serve
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: passo 1, immagine 1 di 2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: passo 3, immagine 1 di 2 Pentax Optio S4i Front and Back Cover Replacement: passo 3, immagine 2 di 2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: passo 4, immagine 1 di 3 Pentax Optio S4i Front and Back Cover Replacement: passo 4, immagine 2 di 3 Pentax Optio S4i Front and Back Cover Replacement: passo 4, immagine 3 di 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: passo 5, immagine 1 di 2 Pentax Optio S4i Front and Back Cover Replacement: passo 5, immagine 2 di 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Conclusione
Nicole Wong
Membro da: 01/30/11
329 Reputazione
3 Guide realizzate
Cal Poly, Team 4-29, Regan Winter 2011 Membro di Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,196
