Salta al contenuto principale
Pentax MZ-S Mirror Drive Lever Replacement
Cosa ti serve
    1. Pentax MZ-S Mirror Drive Lever Replacement, Remove film door: passo 1, immagine 1 di 1
      • Push down the latch to release the film door.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 2, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 2, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 2, immagine 3 di 3
      • Remove two 7.5 mm #00 screws.
      • Remove one 9.0 mm #00 screw.
      • Remove one 13.5 mm #00 screw from inside the battery compartment.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 3, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 3, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: passo 3, immagine 3 di 3
      • Push the button to pop up the flash.
      • Remove one 3.5 mm #00 screw.
      • Remove one 5.5 mm #00 screw.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax MZ-S Mirror Drive Lever Replacement, Lift top cover: passo 4, immagine 1 di 1
      • Carefully lift the top cover away from the body to access wired connections.
      • The top cover is still connected in several locations.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax MZ-S Mirror Drive Lever Replacement, Access flash connections: passo 5, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Access flash connections: passo 5, immagine 2 di 2
      • Peel back the corner of the rubber grip.
      • Remove the small plastic cover.
      • Be careful not to short the wires before the flash capacitors have been properly discharged.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax MZ-S Mirror Drive Lever Replacement, Discharge flash capacitors: passo 6, immagine 1 di 1
      • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax MZ-S Mirror Drive Lever Replacement, Disconnect right flex cable: passo 7, immagine 1 di 1
      • Carefully lift the sides of the white latch.
      • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax MZ-S Mirror Drive Lever Replacement, Disconnect left flex cable: passo 8, immagine 1 di 1
      • Desolder the red wire.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax MZ-S Mirror Drive Lever Replacement, Desolder flash connections: passo 9, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Desolder flash connections: passo 9, immagine 2 di 2
      • Desolder blue, black, brown and green wires.
      • Remove the loose shim washer if present.
      Chiedi a FixBot
      Aggiungi Commento
    10. Pentax MZ-S Mirror Drive Lever Replacement, Desolder the flash flex cable: passo 10, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Desolder the flash flex cable: passo 10, immagine 2 di 2
      • Remove the piece of cellophane tape covering the flex connections.
      • Desolder flex connetions.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: passo 11, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: passo 11, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: passo 11, immagine 3 di 3
      • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
      • Remove one 5mm #00 screw.
      • Remove one 7.5mm #00 screw.
      • Remove two 4.5mm #00 screws.
      • Remove one 5.5mm #00 screw.
      • Remove the plastic frame around the accessory grip contacts.
      • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax MZ-S Mirror Drive Lever Replacement, Remove front left cover: passo 12, immagine 1 di 1
      • Remove one 4.0 mm #00 screw.
      • Remove left cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax MZ-S Mirror Drive Lever Replacement, Remove front cover: passo 13, immagine 1 di 1
      • Remove front cover.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: passo 14, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: passo 14, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: passo 14, immagine 3 di 3
      • Remove one 6.0 mm #00 screw.
      • Remove two 3.5 mm #00 screws.
      • Remove one 5.0 mm #00 screw.
      • Remove the strap lug.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax MZ-S Mirror Drive Lever Replacement, Remove the front right cover: passo 15, immagine 1 di 1
      • Carefully pull the right panel away from the body. It is still attached.
      • Desolder the flex connections.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: passo 16, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: passo 16, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: passo 16, immagine 3 di 3
      • Remove the protective mask around the accessory grip contacts.
      • Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
      • Remove four 4.0 mm #00 screws (standard metric threads).
      • Remove four 4.0 mm #00 screws (plastic threads).
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax MZ-S Mirror Drive Lever Replacement, Desolder speaker: passo 17, immagine 1 di 1
      • Desolder the black and red wires for the speaker.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: passo 18, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: passo 18, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: passo 18, immagine 3 di 3
      • Desolder the white and pink wires.
      • Desolder the red, black and gray wires.
      • Desolder the red, black and orange wires.
      • Desolder the white and blue wires.
      • Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
      • Desolder the flex connection.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: passo 19, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: passo 19, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: passo 19, immagine 3 di 3
      • Desolder red, black, gray and orange wires.
      • Desolder flex contacts.
      • Disconnect flex connector.
      • Desolder yellow and purple wires.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: passo 20, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: passo 20, immagine 2 di 2
      • Desolder black wire.
      • Desolder battery contact tab.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax MZ-S Mirror Drive Lever Replacement, Desolder flex connection above the lens mount: passo 21, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Desolder flex connection above the lens mount: passo 21, immagine 2 di 2
      • Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
      • Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    7. Pentax MZ-S Mirror Drive Lever Replacement, Remove eye piece assembly: passo 22, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Remove eye piece assembly: passo 22, immagine 2 di 2
      • Remove two 5.0 mm #00 screws.
      • Remove the eye piece.
      • The outer cover of the eye piece is only attached with double sided tape and may come away on its own. Make sure the entire eye piece unit is removed before proceeding.
      Chiedi a FixBot
      Aggiungi Commento
    8. Pentax MZ-S Mirror Drive Lever Replacement, Remove lens release switch: passo 23, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Remove lens release switch: passo 23, immagine 2 di 2
      • Remove one #00 screw.
      • Reassembly Note: Ensure that the lower contact catches on the plastic nub and that the contact is open when the lens release button is not pressed.
      Chiedi a FixBot
      Aggiungi Commento
    9. Pentax MZ-S Mirror Drive Lever Replacement, Flip the mirror up: passo 24, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Flip the mirror up: passo 24, immagine 2 di 2
      • Rotate the black gear downward until the mirror flips up into the taking position. It may take several turns.
      • Some failures will result in the mirror appearing to be in the upper position but the internal mechanism is still "down". The mechanism needs to be moved to release the mirror box.
      Chiedi a FixBot
      Aggiungi Commento
    10. Pentax MZ-S Mirror Drive Lever Replacement, Detach flex circuit: passo 25, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Detach flex circuit: passo 25, immagine 2 di 2
      • Remove one 4.0 mm screw.
      • Gently lift the flex circuit away from the housing.
      Chiedi a FixBot
      Aggiungi Commento
    11. Pentax MZ-S Mirror Drive Lever Replacement, Unscrew the mirror box: passo 26, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew the mirror box: passo 26, immagine 2 di 2
      • Remove two 6.5 mm #0 screws.
      • Remove one 8.0 mm #0 screw.
      • Remove one 4.5 mm #00 screw.
      • Remove two 2.5 mm #00 screws.
      • There may be a shim washer here. Remove if loose.
      • Remove one 4.0 mm #00 shoulder screw.
      Chiedi a FixBot
      Aggiungi Commento
    12. Pentax MZ-S Mirror Drive Lever Replacement, Remove the mirror box: passo 27, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Remove the mirror box: passo 27, immagine 2 di 2
      • Push the mirror box up to free it from the bottom plate.
      • Lift the left side of the mirror box and rotate it up and out of the camera body.
      • Be gentle. Keep an eye out for any snagged flex cables or wires. The right side of the mirror box is still connected to the camera body and it cannot be completely removed.
      • Check for shim washers at the mount locations. Note location and remove if loose.
      Chiedi a FixBot
      Aggiungi Commento
    1. Pentax MZ-S Mirror Drive Lever Replacement, Installation Notes: Mirror Box: passo 28, immagine 1 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Installation Notes: Mirror Box: passo 28, immagine 2 di 3 Pentax MZ-S Mirror Drive Lever Replacement, Installation Notes: Mirror Box: passo 28, immagine 3 di 3
      • Install mirror motor plate.
      • Turn the black gear downward to move the mirror through a full cycle.
      • Check that the mirror comes all the way down onto the mirror rest when in the taking position.
      • Check that the aperture control mechanism is moving in its slot.
      • Continue turning the black gear until this hole appears in the opening and the shutter charge lever moves to the right.
      Chiedi a FixBot
      Aggiungi Commento
    2. Pentax MZ-S Mirror Drive Lever Replacement, Remove the aperture control plate: passo 29, immagine 1 di 1
      • Desolder the black wire.
      • Remove one 3.0 mm #00 screw securing the mount LED.
      • Remove five 3.5 mm #00 screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Pentax MZ-S Mirror Drive Lever Replacement, Installation Notes: Aperture control plate: passo 30, immagine 1 di 1
      • Slide the aperture actuator to the left.
      • Push the locking tab up.
      • The aperture actuator should be held in place on the left end of its travel.
      Chiedi a FixBot
      Aggiungi Commento
    4. Pentax MZ-S Mirror Drive Lever Replacement, Remove mirror drive lever: passo 31, immagine 1 di 2 Pentax MZ-S Mirror Drive Lever Replacement, Remove mirror drive lever: passo 31, immagine 2 di 2
      • Remove two drive gears from the mirror box.
      • Remove shutter charge lever spring.
      • Remove mirror drive lever spring.
      • Remove mirror drive lever.
      Chiedi a FixBot
      Aggiungi Commento
    5. Pentax MZ-S Mirror Drive Lever Replacement, Install new mirror drive lever: passo 32, immagine 1 di 1
      • Transfer the two springs from the old drive lever to the new drive lever.
      • Install the new drive lever.
      • Check that all the bias springs are correctly tensioned against the indicated posts.
      Chiedi a FixBot
      Aggiungi Commento
    6. Pentax MZ-S Mirror Drive Lever Replacement, Install drive gears: passo 33, immagine 1 di 1
      • Ensure that the indicated holes are aligned when installing the drive gears.
      Chiedi a FixBot
      Aggiungi Commento
      • Make sure all wires and flex cables are in their proper place before beginning the install. Monitor carefully to avoid pinching things in the wrong place.
      Chiedi a FixBot
      Aggiungi Commento
      • Apply a low DC voltage (3-6 V) to the mirror motor to check the operation of the mirror box. Normal movement in the shutter blades, aperture control and mirror should be observable.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Be careful to route wires and flex cables in the way that they were originally assembled.
Altre 2 persone hanno completato questa guida.
Sam Gustafson
Membro da: 09/01/22
14.634 Reputazione
78 guide realizzate
11Commenti sulla guida
wow, this is not for the faint of heart!
Jonas Bohatsch - Rispondi Condividi
Wow! Respect!!!
akonvisher - Rispondi Condividi
Wow!! respect!!!
I need this part. Anyone know where I can find one?
salazam - Rispondi Condividi
There is an STL file available on the main camera page, which you can send to an online 3D printing service. I would recommend using a lost wax brass casting process. Companies like Shapeways can do this for relatively cheap.
Sam Gustafson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 31
Ultimi 30 giorni: 111
Tutti i Tempi: 3,017
