Salta al contenuto principale
Pentax LX Top Cover (Wind Side) Removal
Cosa ti serve
  1. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: passo 1, immagine 1 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: passo 1, immagine 2 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: passo 1, immagine 3 di 3
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
  2. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: passo 2, immagine 1 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: passo 2, immagine 2 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: passo 2, immagine 3 di 3
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
  3. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: passo 3, immagine 1 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: passo 3, immagine 2 di 3 Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: passo 3, immagine 3 di 3
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
Conclusione
Sam Gustafson
Membro da: 09/01/22
7.682 Reputazione
42 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 29
Tutti i Tempi: 189
