Salta al contenuto principale
Penny Board Trucks Replacement
Cosa ti serve
  1. Penny Board Trucks Replacement, Trucks: passo 1, immagine 1 di 2 Penny Board Trucks Replacement, Trucks: passo 1, immagine 2 di 2
    • Use a skate tool to loosen the bolt in the wheel with an appropriately sized socket.
    • A skate tool will come with all the tools necessary to do this replacement from start to finish.
  2. Penny Board Trucks Replacement: passo 2, immagine 1 di 2 Penny Board Trucks Replacement: passo 2, immagine 2 di 2
    • Remove the wheel by lifting it from the truck.
    • Repeat this step for the other wheel.
  3. Penny Board Trucks Replacement: passo 3, immagine 1 di 2 Penny Board Trucks Replacement: passo 3, immagine 2 di 2
    • After completing the removal of both wheels, your board will look like this.
    • Place the skate tool over the bolt on the truck.
    • Maintain a good grip on the tool and use the Phillips screwdriver to loosen the nuts.
    • Repeat this step for all four screws.
  4. Penny Board Trucks Replacement: passo 4, immagine 1 di 2 Penny Board Trucks Replacement: passo 4, immagine 2 di 2
    • Lift the truck to remove it.
  5. Penny Board Trucks Replacement: passo 5, immagine 1 di 2 Penny Board Trucks Replacement: passo 5, immagine 2 di 2
    • Remove the screws from the board by pulling them out with your hands.
    • Use the Phillips screwdriver to loosen them more, if necessary.
Conclusione
Eduardo Ron
Membro da: 02/17/21
171 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 610
