Salta al contenuto principale
Penguin FZ-8 28” Tower Fan Blade Replacement
Cosa ti serve
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: passo 1, immagine 1 di 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 2, immagine 1 di 3 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 2, immagine 2 di 3 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 2, immagine 3 di 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 3, immagine 1 di 2 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 3, immagine 2 di 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 4, immagine 1 di 2 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 4, immagine 2 di 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 5, immagine 1 di 2 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 5, immagine 2 di 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 6, immagine 1 di 2 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 6, immagine 2 di 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 7, immagine 1 di 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 8, immagine 1 di 2 Penguin FZ-8 28” Tower Fan Blade Replacement: passo 8, immagine 2 di 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: passo 9, immagine 1 di 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Conclusione
Ethan
Membro da: 03/22/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 977
