Salta al contenuto principale
Pebble Time Steel - reparing of a non working button
Cosa ti serve
  1. Pebble Time Steel - reparing of a non working button, Repairing of a non working button: passo 1, immagine 1 di 2 Pebble Time Steel - reparing of a non working button, Repairing of a non working button: passo 1, immagine 2 di 2
    • With opening picks we start to open the watch by lifting up the display bottom from left (about seven o'clock) in counterclockwise direction. In the left side there is a flexband that has to be disconnected.
  2. Pebble Time Steel - reparing of a non working button: passo 2, immagine 1 di 1
    • Three screws are removed.
  3. Pebble Time Steel - reparing of a non working button: passo 3, immagine 1 di 1
    • down on the left, a Flexband is carefully folded up and loosened. Below it, another screw is visible.
    • Remove this screw.
  4. Pebble Time Steel - reparing of a non working button: passo 4, immagine 1 di 2 Pebble Time Steel - reparing of a non working button: passo 4, immagine 2 di 2
    • Then the board can be removed carefully.
    • If you look closely at the keys, you can see that the defective key no longer carries rubber dabs.
    • With a needle, the smallest drops of superglue are dripped into place of the missing rubber.
    • Now put everything together in reverse order. Remove the sealant before applying the display and stick it around with a new Tesa 61395 Tape 1mm.
    • Then insert the display and press down.
Conclusione
Repeat the steps in reverse order to reassemble your device.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Vasco Dunker
Membro da: 12/02/18
256 Reputazione
1 Guida realizzata
2 Commenti
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Kah Kin Yau - Replica
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
Aadi Bhamidipati - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,683
