Salta al contenuto principale
Pebble Time Screen Cover Replacement
Cosa ti serve
  1. Pebble Time Screen Cover Replacement, Screen Cover: passo 1, immagine 1 di 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Cover Replacement: passo 2, immagine 1 di 2 Pebble Time Screen Cover Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Cover Replacement: passo 3, immagine 1 di 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Cover Replacement: passo 4, immagine 1 di 1
    • Carefully, pull apart the cover with the plastic opening tool.
Conclusione
Nicolas Hempe
Membro da: 02/15/17
1.444 Reputazione
5 Guide realizzate
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro di USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membri
7 Guide realizzate
5 Commenti
What does one use to hold the screen on and reseal for waterproofing?
Shannon Oswald - Replica
Using RTV silicon is problematic, I got some on my LCD and now Iā€™m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
Janice Pruett - Replica
This is a brand new Pebble Time watch!!
ā€œCONCLUSION
To reassemble your device, follow these instructions in reverse order.ā€
Yeah, what about an adhesive or sealant? Best practice for doing so?
Adam MacDonald - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,580
