Introduzione
Anleitung zum Austausch der Displayabdeckung der Pebble Time.
Cosa ti serve
Ziehe die Displayabdeckung vorsichtig mit dem Metallspudger vom Gehäuse ab.
Ersetze den Metallspudger durch ein Kunststofföffnungswerkzeug, um die Abdeckung offen zu halten.
Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
Folge der Anleitung in umgekehrter Reihenfolge, um dein Gerät wieder zusammenzubauen.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
5 Commenti
What does one use to hold the screen on and reseal for waterproofing?
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
This is a brand new Pebble Time watch!!
“CONCLUSION
To reassemble your device, follow these instructions in reverse order.”
Yeah, what about an adhesive or sealant? Best practice for doing so?
