Salta al contenuto principale
Pebble Time Circuit Board Replacement
Cosa ti serve
  1. Pebble Time Circuit Board Replacement, Screen Cover: passo 1, immagine 1 di 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: passo 2, immagine 1 di 2 Pebble Time Circuit Board Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: passo 3, immagine 1 di 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: passo 4, immagine 1 di 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: passo 5, immagine 1 di 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: passo 6, immagine 1 di 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: passo 7, immagine 1 di 3 Pebble Time Circuit Board Replacement: passo 7, immagine 2 di 3 Pebble Time Circuit Board Replacement: passo 7, immagine 3 di 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: passo 8, immagine 1 di 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: passo 9, immagine 1 di 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: passo 10, immagine 1 di 3 Pebble Time Circuit Board Replacement: passo 10, immagine 2 di 3 Pebble Time Circuit Board Replacement: passo 10, immagine 3 di 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: passo 11, immagine 1 di 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: passo 12, immagine 1 di 2 Pebble Time Circuit Board Replacement: passo 12, immagine 2 di 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Conclusione
Nicolas Hempe
Membro da: 02/15/17
1.468 Reputazione
5 Guide realizzate
USF Tampa, Team 1-3, Sullivan Spring 2017 Membro di USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,009
