Salta al contenuto principale
Peavy XM4 Input Jack Replacement
Cosa ti serve
  1. Peavy XM4 Input Jack Replacement, Remove Front panel: passo 1, immagine 1 di 1
    • There are two screws at the top and two at the bottom
  2. Peavy XM4 Input Jack Replacement, Remove dial fixings: passo 2, immagine 1 di 2 Peavy XM4 Input Jack Replacement, Remove dial fixings: passo 2, immagine 2 di 2
    • All of the dials have a rubber cover and a nut, these need to be removed from all of the dials. The Jack inputs also have a nut holding them in place, remove these also.
  3. Peavy XM4 Input Jack Replacement, Remove input jack: passo 3, immagine 1 di 2 Peavy XM4 Input Jack Replacement, Remove input jack: passo 3, immagine 2 di 2
    • Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
  4. Peavy XM4 Input Jack Replacement, Solder new jack: passo 4, immagine 1 di 1
    • Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
  5. Peavy XM4 Input Jack Replacement, Re-assemble: passo 5, immagine 1 di 1
    • Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
Conclusione
Josh Walford
Membro da: 01/12/18
199 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 128
