Salta al contenuto principale
Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, immagine 1 di 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, immagine 2 di 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: passo 1, immagine 3 di 3
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Conclusione
Jacob Munson
Membro da: 10/06/16
200 Reputazione
1 Guida realizzata
Cal Poly, Team 20-2, Livingston Fall 2016 Membro di Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 757
