Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show the steps needed to remove the GPS Module. In order to remove the GPS Module, the nose will have to be removed first. Removing the GPS Module will require disconnecting the wire connections on it.
Parti
Nessuna parte specificata.
  1. Begin by removing the velcro strap around the battery. Begin by removing the velcro strap around the battery.
    • Begin by removing the velcro strap around the battery.
  2. While holding onto the nose, gently pull the battery away from the nose. While holding onto the nose, gently pull the battery away from the nose.
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector. Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector. Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Remove the two 7mm T5 torx  screws using a screwdriver. There is one located on each side. Remove the two 7mm T5 torx  screws using a screwdriver. There is one located on each side.
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Take the metal spudger, to remove the double stick tape from the foam.
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Remove the cable from the top of the GPS module.
    • Remove the cable from the top of the GPS module.
  8. Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side. Remove the  4mm T5 Screw holding the GPS Module.
    • Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
    • Remove the 4mm T5 Screw holding the GPS Module.
  9. Remove the GPS board by lifting it off of the metal frame.
    • Remove the GPS board by lifting it off of the metal frame.
Conclusione
Altre 3 persone hanno completato questa guida.
Austin
Membro da: 02/02/2017
164 Reputazione
1 Guida realizzata
UW Tacoma, Team 1-3, Rose Winter 2017 Membro di UW Tacoma, Team 1-3, Rose Winter 2017
UWT-ROSE-W17S1G3
4 Membri
5 Guide realizzate
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
Albert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,086
