Salta al contenuto principale
Parrot AR.Drone 2.0 Central Cross Replacement
Cosa ti serve
Panoramica Video
  1. Parrot AR.Drone 2.0 Central Cross Replacement, Mainboard and Navigation Board: passo 1, immagine 1 di 1
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Central Cross Replacement: passo 2, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 2, immagine 2 di 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Central Cross Replacement: passo 3, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 3, immagine 2 di 2
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  4. Parrot AR.Drone 2.0 Central Cross Replacement: passo 4, immagine 1 di 3 Parrot AR.Drone 2.0 Central Cross Replacement: passo 4, immagine 2 di 3 Parrot AR.Drone 2.0 Central Cross Replacement: passo 4, immagine 3 di 3
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  5. Parrot AR.Drone 2.0 Central Cross Replacement: passo 5, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 5, immagine 2 di 2
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
    How can I get that connector, the one it’s disconnected?
    gui txr - Replica
  6. Parrot AR.Drone 2.0 Central Cross Replacement: passo 6, immagine 1 di 1
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  7. Parrot AR.Drone 2.0 Central Cross Replacement: passo 7, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 7, immagine 2 di 2
    • Carefully pull the secondary board from the mainboard.
  8. Parrot AR.Drone 2.0 Central Cross Replacement: passo 8, immagine 1 di 3 Parrot AR.Drone 2.0 Central Cross Replacement: passo 8, immagine 2 di 3 Parrot AR.Drone 2.0 Central Cross Replacement: passo 8, immagine 3 di 3
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  9. Parrot AR.Drone 2.0 Central Cross Replacement: passo 9, immagine 1 di 1
    • Release the rubber clip holding the USB and battery power cable to the body.
  10. Parrot AR.Drone 2.0 Central Cross Replacement: passo 10, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 10, immagine 2 di 2
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  11. Parrot AR.Drone 2.0 Central Cross Replacement: passo 11, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 11, immagine 2 di 2
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  12. Parrot AR.Drone 2.0 Central Cross Replacement: passo 12, immagine 1 di 2 Parrot AR.Drone 2.0 Central Cross Replacement: passo 12, immagine 2 di 2
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  13. Parrot AR.Drone 2.0 Central Cross Replacement: passo 13, immagine 1 di 1
    • The mainboard is now fully detached and can be removed.
  14. Parrot AR.Drone 2.0 Central Cross Replacement, Central Cross: passo 14, immagine 1 di 1
    • Using a nylon spudger, peel off the four pieces of plastic securing the frame to the body.
  15. Parrot AR.Drone 2.0 Central Cross Replacement: passo 15, immagine 1 di 1
    • Carefully maneuver the four arms of the drone’s central cross until it detaches from the body by pulling apart the foam surrounding the arms.
    between arm 1 and arm 2 there is a little triangle on the central cross, that should point to the front.
    deebee122 - Replica
  16. Parrot AR.Drone 2.0 Central Cross Replacement: passo 16, immagine 1 di 1
    • The central cross can now be removed and replaced.
    deebee122 - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
David Hoyt
Membro da: 04/09/10
4.023 Reputazione
43 Guide realizzate
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
63 Guide realizzate
2 Commenti
If the crossbones are off just a bit would that effect the flight?
John Wurst - Replica
So once I have removed the central cross, how do I put it all back together again?? I feel as though this is letting your guide down!!!!
Jacob Kenworthy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,137
