Salta al contenuto principale
Pantech Matrix Motherboard Replacement
Cosa ti serve
  1. Pantech Matrix Motherboard Replacement, Phone Orientation: passo 1, immagine 1 di 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Motherboard Replacement, Phone Orientation: passo 2, immagine 1 di 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Motherboard Replacement, Remove Back Cover: passo 3, immagine 1 di 2 Pantech Matrix Motherboard Replacement, Remove Back Cover: passo 3, immagine 2 di 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Motherboard Replacement, Lift Battery: passo 4, immagine 1 di 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Motherboard Replacement, Remove Battery: passo 5, immagine 1 di 1
    • Remove the battery from its dock.
  6. Pantech Matrix Motherboard Replacement, Slide SIM Card Out: passo 6, immagine 1 di 3 Pantech Matrix Motherboard Replacement, Slide SIM Card Out: passo 6, immagine 2 di 3 Pantech Matrix Motherboard Replacement, Slide SIM Card Out: passo 6, immagine 3 di 3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Motherboard Replacement, Remove Phone Screws: passo 7, immagine 1 di 2 Pantech Matrix Motherboard Replacement, Remove Phone Screws: passo 7, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Motherboard Replacement, Remove Phone Casing: passo 8, immagine 1 di 2 Pantech Matrix Motherboard Replacement, Remove Phone Casing: passo 8, immagine 2 di 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
  9. Pantech Matrix Motherboard Replacement, Remove Camera Screws: passo 9, immagine 1 di 2 Pantech Matrix Motherboard Replacement, Remove Camera Screws: passo 9, immagine 2 di 2
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
  10. Pantech Matrix Motherboard Replacement, Expose Keypad: passo 10, immagine 1 di 1
    • Carefully lift up the motherboard to expose the back of the keypad.
  11. Pantech Matrix Motherboard Replacement, Remove Keypad: passo 11, immagine 1 di 2 Pantech Matrix Motherboard Replacement, Remove Keypad: passo 11, immagine 2 di 2
    • Use spudger to gently pry the keypad away from the rest of the phone.
  12. Pantech Matrix Motherboard Replacement, Remove Motherboard: passo 12, immagine 1 di 3 Pantech Matrix Motherboard Replacement, Remove Motherboard: passo 12, immagine 2 di 3 Pantech Matrix Motherboard Replacement, Remove Motherboard: passo 12, immagine 3 di 3
    • Grip the motherboard and gently pull to separate it from the rest of the phone.
Conclusione
Zeel Patel
Membro da: 10/13/14
1.096 Reputazione
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 317
