Salta al contenuto principale
Pantech Burst Motherboard Replacement
Cosa ti serve
  1. Pantech Burst Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Pantech Burst Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Pantech Burst Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Pantech Burst Motherboard Replacement: passo 2, immagine 1 di 3 Pantech Burst Motherboard Replacement: passo 2, immagine 2 di 3 Pantech Burst Motherboard Replacement: passo 2, immagine 3 di 3
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Pantech Burst Motherboard Replacement: passo 3, immagine 1 di 3 Pantech Burst Motherboard Replacement: passo 3, immagine 2 di 3 Pantech Burst Motherboard Replacement: passo 3, immagine 3 di 3
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Pantech Burst Motherboard Replacement: passo 4, immagine 1 di 2 Pantech Burst Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the SD card if there is one inserted into the phone.
  5. Pantech Burst Motherboard Replacement: passo 5, immagine 1 di 3 Pantech Burst Motherboard Replacement: passo 5, immagine 2 di 3 Pantech Burst Motherboard Replacement: passo 5, immagine 3 di 3
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  6. Pantech Burst Motherboard Replacement: passo 6, immagine 1 di 3 Pantech Burst Motherboard Replacement: passo 6, immagine 2 di 3 Pantech Burst Motherboard Replacement: passo 6, immagine 3 di 3
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  7. Pantech Burst Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  8. Pantech Burst Motherboard Replacement: passo 8, immagine 1 di 3 Pantech Burst Motherboard Replacement: passo 8, immagine 2 di 3 Pantech Burst Motherboard Replacement: passo 8, immagine 3 di 3
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
Conclusione
Kyle Kurashima
Membro da: 09/29/15
111 Reputazione
1 Guida realizzata
Cal Poly, Team 15-1, Green Fall 2015 Membro di Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 460
