Salta al contenuto principale
Pandigital Super Nova Screen Replacement
Cosa ti serve
  1. Pandigital Super Nova Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Screen Replacement: passo 2, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 2, immagine 2 di 2
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Screen Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Screen Replacement: passo 4, immagine 1 di 1
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Screen Replacement: passo 5, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 5, immagine 2 di 2
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Screen Replacement, Front Facing Camera: passo 6, immagine 1 di 2 Pandigital Super Nova Screen Replacement, Front Facing Camera: passo 6, immagine 2 di 2
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Screen Replacement: passo 7, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
  8. Pandigital Super Nova Screen Replacement, Screen: passo 8, immagine 1 di 2 Pandigital Super Nova Screen Replacement, Screen: passo 8, immagine 2 di 2
    • Use a screwdriver to remove the six .15 mm screws that hold the motherboard in place. Set aside.
  9. Pandigital Super Nova Screen Replacement: passo 9, immagine 1 di 3 Pandigital Super Nova Screen Replacement: passo 9, immagine 2 di 3 Pandigital Super Nova Screen Replacement: passo 9, immagine 3 di 3
    • Remove the eleven screws that hold the screen to the base. Eight are .15 mm and three are .11 mm.
  10. Pandigital Super Nova Screen Replacement: passo 10, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 10, immagine 2 di 2
    • Remove the motherboard from the tablet using a nylon spudger.
    • A regular black nylon spudger should be used to avoid damaging the motherboard.
  11. Pandigital Super Nova Screen Replacement: passo 11, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 11, immagine 2 di 2
    Compra
    • Use tweezers to carefully remove the connector between the screen to the tablet.
  12. Pandigital Super Nova Screen Replacement: passo 12, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 12, immagine 2 di 2
    • Use a pry tool to carefully separate the motherboard from the hard casing.
    • Excessive force in this step can damage your device.
  13. Pandigital Super Nova Screen Replacement: passo 13, immagine 1 di 1
    • Lift the motherboard out of the tablet.
    • Remove the second connector between the screen and the motherboard.
  14. Pandigital Super Nova Screen Replacement: passo 14, immagine 1 di 3 Pandigital Super Nova Screen Replacement: passo 14, immagine 2 di 3 Pandigital Super Nova Screen Replacement: passo 14, immagine 3 di 3
    • Pry the silver screen box from away from the device.
    • Open each of the four clips securing the screen box to open it.
  15. Pandigital Super Nova Screen Replacement: passo 15, immagine 1 di 2 Pandigital Super Nova Screen Replacement: passo 15, immagine 2 di 2
    • Lift the screen out of its protective box.
    • If the protective box is damaged, it will also need replacing.
Conclusione
Altre 2 persone hanno completato questa guida.
Texas Tech, Team 1-2, Bennett Fall 2016 Membro di Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 256
