Salta al contenuto principale
Pandigital Super Nova Front Facing Camera Replacement
Cosa ti serve
  1. Pandigital Super Nova Front Facing Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Front Facing Camera Replacement: passo 2, immagine 1 di 2 Pandigital Super Nova Front Facing Camera Replacement: passo 2, immagine 2 di 2
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Front Facing Camera Replacement: passo 3, immagine 1 di 1
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Front Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Front Facing Camera Replacement: passo 5, immagine 1 di 2 Pandigital Super Nova Front Facing Camera Replacement: passo 5, immagine 2 di 2
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: passo 6, immagine 1 di 2 Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: passo 6, immagine 2 di 2
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Front Facing Camera Replacement: passo 7, immagine 1 di 2 Pandigital Super Nova Front Facing Camera Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Conclusione
Texas Tech, Team 1-2, Bennett Fall 2016 Membro di Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 110
