Salta al contenuto principale
Pandigital Novel PRD07T10WWH7 Battery Replacement
Cosa ti serve
  1. Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: passo 1, immagine 1 di 2 Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 2, immagine 1 di 2 Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 2, immagine 2 di 2
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the 12 4mm screws on the outer area of the gray area exposed by removing the back panels.
  4. Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 4, immagine 1 di 2 Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 4, immagine 2 di 2
    • Carefully pry the back of the device from the front panel and motherboard. There are a series of clips holding them together that need to be separated.
  5. Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 5, immagine 1 di 2 Pandigital Novel PRD07T10WWH7 Battery Replacement: passo 5, immagine 2 di 2
    • Now, lift up the gray piece, unplug the battery connector, and the battery can be removed from the case.
Conclusione
Carl Weber
Membro da: 10/21/16
328 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,254
