Salta al contenuto principale
Panasonic VDR-D220 DVD Viewfinder Replacement
Cosa ti serve
  1. Panasonic VDR-D220 DVD Viewfinder Replacement, Viewfinder: passo 1, immagine 1 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement, Viewfinder: passo 1, immagine 2 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement, Viewfinder: passo 1, immagine 3 di 3
    • Use your Phillips #0 screwdriver to remove the three 5mm screws on top of the camera.
    • Remove the metal bracket.
  2. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 2, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 2, immagine 2 di 2
    • Rotate the camera to show the bottom side of the camera.
    • Remove the four 5mm Phillips #0 screws on the bottom side of the camera.
  3. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 3, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 3, immagine 2 di 2
    • Remove one 5mm screw by using Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 4, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 4, immagine 2 di 2
    • Use a spudger to pry the top-front part of the camera from the main body.
    • Gently slide the top portion of the camera forward reveling more screws.
    • Be sure not to slide the front portion too far, as there are still some cable connections joining the two portions.
  5. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 5, immagine 1 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 5, immagine 2 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 5, immagine 3 di 3
    • Flip the camera on the right side.
    • Gently pull the front part from the main body.
    • Do not pull too hard because of the ZIF connector cable.
    • Use the plastic opening tool to disconnect the connection point safely.
    • Press the tab with plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 6, immagine 1 di 1
    • Flip the camera on the bottom side again.
    • Remove one more 5mm screw with your Phillips #0 screwdriver that was previously covered.
  7. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 7, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 7, immagine 2 di 2
    • Go to the battery basement's side.
    • Use your Phillips #0 screwdriver remove the two 5mm screws on the battery base of the camera.
  8. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 8, immagine 1 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 8, immagine 2 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 8, immagine 3 di 3
    • Rotate the camera to the left side, where the side port is located.
    • Open the side port door.
  9. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 9, immagine 1 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 9, immagine 2 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 9, immagine 3 di 3
    • Remove three 5mm screws inside the side ports by using Phillips #0 screwdriver.
    • Begin to lift the left side of the camera from the main body.
    • Don't separate the camera sections too far, as there are more cable connections that need to be disconnected.
  10. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 10, immagine 1 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 10, immagine 2 di 3 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 10, immagine 3 di 3
    • Rotate the camera to the battery side.
    • Gently pull the side of the camera apart until the cables are exposed.
    • Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
  11. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 11, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 11, immagine 2 di 2
    • Remove one 5mm screw from the side of the battery base with the Phillips #0 screwdriver.
    • Take off the battery's base from the camera.
  12. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 12, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 12, immagine 2 di 2
    • Remove another ribbon cable that runs from the viewfinder to the top of the motherboard. Use your plastic opening tool to disconnect the connection point safely.
  13. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 13, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 13, immagine 2 di 2
    • Remove the three 5mm screws on the left side of the viewfinder with your Phillips #0 screwdriver.
  14. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 14, immagine 1 di 1
    • Gently pull the entire viewfinder away from the camera in a lifting motion away and make sure nothing is still connected with it.
  15. Panasonic VDR-D220 DVD Viewfinder Replacement: passo 15, immagine 1 di 2 Panasonic VDR-D220 DVD Viewfinder Replacement: passo 15, immagine 2 di 2
    • Separate the viewfinder from the metal piece.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 231
