Salta al contenuto principale
Panasonic VDR-D220 DVD Camera Front lens Element Replacement
Cosa ti serve
  1. Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, immagine 1 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, immagine 2 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement, Camera lens: passo 1, immagine 3 di 3
    • Remove one 5mm screw on the bottom side of the camera with a Phillips #0 screwdriver.
  2. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, immagine 1 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, immagine 2 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 2, immagine 3 di 3
    • Open the side port door.
  3. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 3, immagine 1 di 2 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 3, immagine 2 di 2
    • Remove one 5mm screw inside the side port with your Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 4, immagine 1 di 2 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 4, immagine 2 di 2
    • Using a plastic spudger, pry to disconnect the top-front part of the camera.
    • Slide the top portion of the camera forward revealing a ribbon cable.
  5. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, immagine 1 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, immagine 2 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 5, immagine 3 di 3
    • Flip the camera on the right side.
    • Gently pull the front part from the main body to reveal the cables connecting them.
    • Do not pull too hard because of the ZIF connector cable.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with a plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, immagine 1 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, immagine 2 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 6, immagine 3 di 3
    • Look at the camera from the front side.
    • Remove four 5mm screws using a Phillips #0 screwdriver.
    • There are two 5mm screws on each side of the lens, for a total of four screws.
  7. Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, immagine 1 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, immagine 2 di 3 Panasonic VDR-D220 DVD Camera Front lens Element Replacement: passo 7, immagine 3 di 3
    • Pull the front element lens gently away from the camera.
    • In some cases the lens need not be replaced completely. Sometimes cleaning the lens with a microfiber cloth and isopropyl alcohol will alleviate blurry video issues.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 180
