Salta al contenuto principale
Panasonic Toughbook CF-53 Optical Drive Replacement
Cosa ti serve
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 2 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: passo 1, immagine 2 di 2
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,604
