Salta al contenuto principale
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, immagine 1 di 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, immagine 2 di 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: passo 2, immagine 1 di 2 Panasonic Toughbook CF-53 Battery Replacement: passo 2, immagine 2 di 2
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: passo 3, immagine 1 di 3 Panasonic Toughbook CF-53 Battery Replacement: passo 3, immagine 2 di 3 Panasonic Toughbook CF-53 Battery Replacement: passo 3, immagine 3 di 3
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 110
Tutti i Tempi: 5,994
