Salta al contenuto principale
Panasonic Toughbook CF-29 RAM Replacement
Cosa ti serve
  1. Panasonic Toughbook CF-29 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 RAM Replacement: passo 2, immagine 1 di 2 Panasonic Toughbook CF-29 RAM Replacement: passo 2, immagine 2 di 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 RAM Replacement: passo 4, immagine 1 di 1
    • Pull the clips aside to release and remove the RAM.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
26 Guide realizzate
2 Commenti
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - Replica
there is another ram slot you failed to mention
sparkynaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 18,357
