Salta al contenuto principale
Panasonic Toughbook CF-29 Optical Drive Replacement
  1. Panasonic Toughbook CF-29 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 2, immagine 1 di 2 Panasonic Toughbook CF-29 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Optical Drive Replacement: passo 5, immagine 1 di 2 Panasonic Toughbook CF-29 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Push the exposed switch to the left to eject the optical drive.
Conclusione
Altre 2 persone hanno completato questa guida.
Clint Kirsop
Membro da: 04/13/10
109 Reputazione
4 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
26 Guide realizzate
Un commento
What kind of USB enclosure would this fit in?
Terence Higgins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,829
