Salta al contenuto principale
Panasonic Toughbook CF-29 Heat Sink Replacement
Cosa ti serve
  1. Panasonic Toughbook CF-29 Heat Sink Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 2, immagine 1 di 2 Panasonic Toughbook CF-29 Heat Sink Replacement: passo 2, immagine 2 di 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Heat Sink Replacement, Back Cover: passo 3, immagine 1 di 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 4, immagine 1 di 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 5, immagine 1 di 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 6, immagine 1 di 2 Panasonic Toughbook CF-29 Heat Sink Replacement: passo 6, immagine 2 di 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 7, immagine 1 di 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 8, immagine 1 di 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Heat Sink Replacement, Heat Sink: passo 9, immagine 1 di 1
    • Locate the heat sink on the underside of the back cover.
    • It is the U shaped metallic piece.
  10. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 10, immagine 1 di 1
    • Remove the four screws with a Phillips size 1 screwdriver.
    • One on each of the ends
    • Two on the base of the U shape
  11. Panasonic Toughbook CF-29 Heat Sink Replacement: passo 11, immagine 1 di 1
    • Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
Conclusione
Clint Kirsop
Membro da: 04/13/10
109 Reputazione
4 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,796
