Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide provides the steps to remove the back cover. This process is necessary to access many of the components inside.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Flip the device upside down with the handle facing away from you.
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Slide the latch cover to the right.
    • Slide the latch cover to the right.
  5. Push the exposed switch to the left to eject the optical drive. Push the exposed switch to the left to eject the optical drive.
    • Push the exposed switch to the left to eject the optical drive.
  6. Begin by turning the laptop upside down with the handle towards you.
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Remove the panel and set it aside.
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Be careful when lifting the cover as you may damage some connections.
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Now the back cover should be off and you can access the inside of the casing.
    • Now the back cover should be off and you can access the inside of the casing.
Conclusione
Rohun Heesen
Membro da: 13/04/2010
345 Reputazione
2 Guide realizzate
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
24 Guide realizzate
thanks for this crucial tuatorial >
Joe Gutierrez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 9,540
