Salta al contenuto principale
Panasonic Toughbook CF-29 Back Cover Replacement
Cosa ti serve
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: passo 2, immagine 1 di 2 Panasonic Toughbook CF-29 Back Cover Replacement: passo 2, immagine 2 di 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: passo 4, immagine 1 di 1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: passo 5, immagine 1 di 2 Panasonic Toughbook CF-29 Back Cover Replacement: passo 5, immagine 2 di 2
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: passo 6, immagine 1 di 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: passo 7, immagine 1 di 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: passo 8, immagine 1 di 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: passo 9, immagine 1 di 2 Panasonic Toughbook CF-29 Back Cover Replacement: passo 9, immagine 2 di 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: passo 10, immagine 1 di 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: passo 11, immagine 1 di 1
    • Now the back cover should be off and you can access the inside of the casing.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 27-93, Amido Spring 2010 Membro di Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Membri
26 Guide realizzate
Un commento
thanks for this crucial tuatorial >
Joe Gutierrez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 10,095
