Salta al contenuto principale
Panasonic SC-PM31 CD Player Replacement
Cosa ti serve
  1. Panasonic SC-PM31 CD Player Replacement, Removing the side and back screws: passo 1, immagine 1 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the side and back screws: passo 1, immagine 2 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the side and back screws: passo 1, immagine 3 di 3
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
  2. Panasonic SC-PM31 CD Player Replacement, Removing the panels: passo 2, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Removing the panels: passo 2, immagine 2 di 2
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
  3. Panasonic SC-PM31 CD Player Replacement, Removing the white ribbon wire: passo 3, immagine 1 di 1
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
  4. Panasonic SC-PM31 CD Player Replacement, Removing the top panel: passo 4, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Removing the top panel: passo 4, immagine 2 di 2
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
  5. Panasonic SC-PM31 CD Player Replacement, Removing the top black wire: passo 5, immagine 1 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the top black wire: passo 5, immagine 2 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the top black wire: passo 5, immagine 3 di 3
    • Unlike the other ribbon wire connectors, the white connector (in this step only) is not attached to the ribbon wire. It can not, and should not, be pulled out completely.
    • Locate the white connector where the top black ribbon wire attaches to the green and black circuit board.
    • Pinch the tabs on the white connector and pull it partially out.
    • Hold the black ribbon wire directly and pull it the rest of the way out.
  6. Panasonic SC-PM31 CD Player Replacement: passo 6, immagine 1 di 1
    • Pull the white ribbon cable from its base on the tan circuit board-located on the side of the system opposite the power button.
  7. Panasonic SC-PM31 CD Player Replacement, Removing the front panel: passo 7, immagine 1 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the front panel: passo 7, immagine 2 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the front panel: passo 7, immagine 3 di 3
    • On the bottom sides of the front panel, pull the tabs outward to unclip the clasps.
    • Tilt the whole system up and unlock the bottom clasp of the front panel by pulling it toward you.
    • After placing the system back down, pull the front panel toward you to remove it.
  8. Panasonic SC-PM31 CD Player Replacement, Removing the back panel screws: passo 8, immagine 1 di 1
    • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
  9. Panasonic SC-PM31 CD Player Replacement, Removing the back panel: passo 9, immagine 1 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the back panel: passo 9, immagine 2 di 3 Panasonic SC-PM31 CD Player Replacement, Removing the back panel: passo 9, immagine 3 di 3
    • With a gentle tug, unplug the red and black cable from the tan circuit board.
    • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
    • Slide the back panel toward you and off of the unit.
  10. Panasonic SC-PM31 CD Player Replacement, Preparing to remove the mainboard: passo 10, immagine 1 di 3 Panasonic SC-PM31 CD Player Replacement, Preparing to remove the mainboard: passo 10, immagine 2 di 3 Panasonic SC-PM31 CD Player Replacement, Preparing to remove the mainboard: passo 10, immagine 3 di 3
    • Rotate the device so that the front is facing towards you.
    • Remove the four 5.5mm #2 Phillips screws securing the mainboard (the black flat circuit board).
    • Remove the cable connector from the mainboard by pulling the connector up.
    • Detach the two side ribbon wires on the green side of the tan and green circuit board by pulling them out of the bottom.
  11. Panasonic SC-PM31 CD Player Replacement, Removing the mainboard: passo 11, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Removing the mainboard: passo 11, immagine 2 di 2
    • Slide the mainboard away from the black and green circuit board and then up.
  12. Panasonic SC-PM31 CD Player Replacement, Removing the CD assembly case: passo 12, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Removing the CD assembly case: passo 12, immagine 2 di 2
    • Rotate the device so that the side with the circuit board is facing towards you.
    • Pull the sides of the metal CD assembly case out slightly to disengage the clasps holding the encasing down.
    • Repeat the previous step on the other side.
    • Lift the metal CD assembly case up and away from the device.
  13. Panasonic SC-PM31 CD Player Replacement, Removing the plastic grid: passo 13, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Removing the plastic grid: passo 13, immagine 2 di 2
    • Push down on the two black clasps and pull the plastic grid towards you.
    • Lift the plastic grid off of the CD assembly.
  14. Panasonic SC-PM31 CD Player Replacement, Unscrewing the CD assembly: passo 14, immagine 1 di 2 Panasonic SC-PM31 CD Player Replacement, Unscrewing the CD assembly: passo 14, immagine 2 di 2
    • Remove the two 9.5mm screws holding the CD assembly to the base.
    • One of the screws in this step is inside the CD assembly. You will need to use a long screwdriver to reach in and unscrew it.
    • When reassembling the device, put the front panel on before screwing, as it will help line up the screw holes correctly.
  15. Panasonic SC-PM31 CD Player Replacement, Removing the CD assembly: passo 15, immagine 1 di 1
    • Lift the CD assembly away from the bottom panel.
Conclusione
Altre 3 persone hanno completato questa guida.
Jessica Chao
Membro da: 09/29/14
626 Reputazione
5 Guide realizzate
Cal Poly, Team 13-7, Forte Fall 2014 Membro di Cal Poly, Team 13-7, Forte Fall 2014
CPSU-FORTE-F14S13G7
5 Membri
7 Guide realizzate
6 Commenti
Hello
Where can I order such a cd tray ?
Regards
Pierre Godicheau - Replica
is there a co. in orange county, ca. 92637 that will “unstick” the 2 CD trays?
chuck faria - Replica
Not a good product! after 12 years of moderate use, the cd trays will not open or close. Panasonic Canada maintains the cd changer is no longer
available. Taking the device apart and reassembling it was about 8 hours of futility! No more Panasonic products!
michael woodard - Replica
Is there more information on the CD changer?
One tray, think #5, is stuck out and cannot be pushed back in. #4 tray is all the way forward in the play position. #s 2 & 3 are just inside the front, neutral position I guess. There was a CD-R jammed in the changer I managed to get out.
There appear to be stops in the system tray positions and do not know where the sensors are. Ready to put back together but reluctant to put power to it until I feel confident no further complications with the CD changer system will occur.
Any thoughts please. Per change, any SAMS or similar docs on this?
Thnx for a response.
aerhard@cox.net
Alex Erhard - Replica
I've found this vidio some time ago, it is helpful. It's in spanish but you can put subtitles on it. I disassamble mine folowing its steps, but my CD tray was too broken :'(
https://www.youtube.com/watch?v=dld-wrKB...
Víctor Velazquez -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 54
Tutti i Tempi: 5,625
