Cosa ti serve
With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
Now rotate the device 180 degrees and remove the second screw.
Remove the screw that is on the right side of the panel facing you.
Remove all screws with a phillips head screwdriver.
Altre 2 persone hanno completato questa guida.
