Salta al contenuto principale
Panasonic SA-HT810V DVD Drive Replacement
Cosa ti serve
  1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, immagine 1 di 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, immagine 2 di 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, immagine 3 di 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
  2. Panasonic SA-HT810V DVD Drive Replacement: passo 2, immagine 1 di 2 Panasonic SA-HT810V DVD Drive Replacement: passo 2, immagine 2 di 2
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
  3. Panasonic SA-HT810V DVD Drive Replacement: passo 3, immagine 1 di 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Panasonic SA-HT810V DVD Drive Replacement: passo 4, immagine 1 di 3 Panasonic SA-HT810V DVD Drive Replacement: passo 4, immagine 2 di 3 Panasonic SA-HT810V DVD Drive Replacement: passo 4, immagine 3 di 3
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
  5. Panasonic SA-HT810V DVD Drive Replacement: passo 5, immagine 1 di 1
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Panasonic SA-HT810V DVD Drive Replacement: passo 6, immagine 1 di 2 Panasonic SA-HT810V DVD Drive Replacement: passo 6, immagine 2 di 2
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
  7. Panasonic SA-HT810V DVD Drive Replacement: passo 7, immagine 1 di 1
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
  8. Panasonic SA-HT810V DVD Drive Replacement: passo 8, immagine 1 di 1
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 16-5, Maness Spring 2010 Membro di Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,442
