Salta al contenuto principale
Panasonic PV-GS9 LCD panel replacement
Cosa ti serve
  1. Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: passo 1, immagine 1 di 3 Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: passo 1, immagine 2 di 3 Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: passo 1, immagine 3 di 3
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 LCD panel replacement: passo 2, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement: passo 2, immagine 2 di 2
    • Open the tape compartment.
    • Flip over the camcorder and find the two 4.5mm screws, which are approximately 2 inches apart.
    • Using a #00 Phillips screwdriver, remove the screws
  3. Panasonic PV-GS9 LCD panel replacement: passo 3, immagine 1 di 3 Panasonic PV-GS9 LCD panel replacement: passo 3, immagine 2 di 3 Panasonic PV-GS9 LCD panel replacement: passo 3, immagine 3 di 3
    • Use a plastic prying tool, remove the gray trim piece by opening and gently prying it off from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 LCD panel replacement: passo 4, immagine 1 di 1
    • Rotate the camcorder so that the camera lens is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Organize the screws in a sorting compartment to avoid losing them.
  5. Panasonic PV-GS9 LCD panel replacement: passo 5, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement: passo 5, immagine 2 di 2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 LCD panel replacement: passo 6, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement: passo 6, immagine 2 di 2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 LCD panel replacement: passo 7, immagine 1 di 1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 LCD panel replacement: passo 8, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement: passo 8, immagine 2 di 2
    • Carefully detatch the front cover from the body of the camcorder.
    • This should come apart with relative ease; however, a plastic pryer tool may help remove the panel if it is struggling to come apart.
    • Be careful as there is a ribbon cable attached to the front panel and the camcorder body, DO NOT tug at it when you remove this panel.
  9. Panasonic PV-GS9 LCD panel replacement: passo 9, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement: passo 9, immagine 2 di 2
    • Using your fingers, carefully pull the ribbon cable away from the logic board to disconnect it.
  10. Panasonic PV-GS9 LCD panel replacement, LCD Panel Removal: passo 10, immagine 1 di 2 Panasonic PV-GS9 LCD panel replacement, LCD Panel Removal: passo 10, immagine 2 di 2
    • Remove the indicated 4.5mm screws from the LCD side of the camera.
  11. Panasonic PV-GS9 LCD panel replacement: passo 11, immagine 1 di 3 Panasonic PV-GS9 LCD panel replacement: passo 11, immagine 2 di 3 Panasonic PV-GS9 LCD panel replacement: passo 11, immagine 3 di 3
    • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
    • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
    • Remove the panel from the camcorder.
    • Using two tools can help for stability.
  12. Panasonic PV-GS9 LCD panel replacement: passo 12, immagine 1 di 3 Panasonic PV-GS9 LCD panel replacement: passo 12, immagine 2 di 3 Panasonic PV-GS9 LCD panel replacement: passo 12, immagine 3 di 3
    • Before removing the LCD panel from the camcorder, disconnect all the ribbon cables joining the LCD panel to the logic board.
    • There may be multiple ribbon cables attached to the same point on the logic board.
Conclusione
Cal Poly, Team 7-9, Maness Spring 2010 Membro di Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 4,005
