Salta al contenuto principale
Panasonic Lumx DMC-ZS19 LCD Screen Replacement
Cosa ti serve
  1. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
Conclusione
USF Tampa, Team 14-1, Meier Fall 2015 Membro di USF Tampa, Team 14-1, Meier Fall 2015
USFT-MEIER-F15S14G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 301
