Salta al contenuto principale
Panasonic Lumix ZS50 Flash Assembly Replacement
Cosa ti serve
  1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: passo 1, immagine 1 di 2 Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 2, immagine 1 di 2 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 2, immagine 2 di 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 3, immagine 1 di 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 4, immagine 1 di 1
    • The battery should now be released; you may now remove the battery from the camera body.
  5. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: passo 5, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: passo 5, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: passo 5, immagine 3 di 3
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
  6. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 6, immagine 1 di 2 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the casing from the camera by hand or using a plastic opening tool.
  7. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 7, immagine 1 di 2 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 7, immagine 2 di 2
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
  8. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 8, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 8, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 8, immagine 3 di 3
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
  9. Attenzione: i passaggi 9-12 provengono da una guida contrassegnata come in corso.
    Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: passo 9, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: passo 9, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: passo 9, immagine 3 di 3
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
  10. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 10, immagine 1 di 2 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 10, immagine 2 di 2
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
  11. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 11, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 11, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 11, immagine 3 di 3
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
  12. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 12, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 12, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 12, immagine 3 di 3
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
  13. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: passo 13, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: passo 13, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: passo 13, immagine 3 di 3
    • Remove the one screw holding the camera and the flash component together.
    • Gently pull the flash component out of the camera body.
  14. Panasonic Lumix ZS50 Flash Assembly Replacement: passo 14, immagine 1 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 14, immagine 2 di 3 Panasonic Lumix ZS50 Flash Assembly Replacement: passo 14, immagine 3 di 3
    • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
    • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
Conclusione
Baylor, Team 8-5, Whitney Spring 2017 Membro di Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Membri
4 Guide realizzate
Un commento
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 219
